C6 differential
Old Sep 15, 2019 | 09:58 PM
Brandon shannon's Avatar
Brandon shannon
1st Gear
Default C6 differential
So I just blew my stock 2006 base model differential I would like to put a zo6 differential in. Is there any certain stuff I need to do or is it just a direct bolt in?
Old Sep 15, 2019 | 10:59 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
For an A6 it is a direct bolt in of the Z06 rear into the Vette -
However for a MN6 it is not a direct bolt-in for a Z06 rear, they are not compatible -
Thanks,Matt
Old Sep 16, 2019 | 12:22 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
If you're using it in an A6 car you'll also need to use the differential cooler or install a replacement cover that I think Zip Corvette sells.
To C6 differential
