EU vette help!
Old Sep 22, 2019 | 03:15 PM
Adambrown88's Avatar
Adambrown88
Cruising
Default EU vette help!
I want to separate my rear turn signal from the side and brake lights, I understand you can get a eu harness and reprogram the bcm with tech2 but you lose tpms. Is there any other way I can get around this? Can I piggyback off the front turn signals?
Old Sep 22, 2019 | 09:42 PM
Richi's Avatar
Richi
I have an EU vette and I have someone modified a US harness to install a set of led rear tail light
So modifying the EU one should also be possible without reprograming the BCM.
Old Sep 23, 2019 | 05:17 AM
Adambrown88
Cruising
Have you got any pics of the modified loom? I still have the US one. Not bought a Eu loom.
Old Sep 23, 2019 | 09:20 PM
Richi's Avatar
Richi
Unfortunately I have no picture but he added some electric components and I have absolutely no knowledge about electricity
Here is his email address so you can ask him info@us-import-specialist.com
His name is Jérome.
Old Oct 4, 2019 | 05:32 PM
Fishy Dave's Avatar
Fishy Dave
I kept my US loom and altered the following for use in the UK.
Radioflyer switchback front indicator/white running lights. Splice the side markers into this so they flash amber with the indicators (amber leds).
Radioflyer fog/reverse light kit and fog switch.
Either EU-C or Cartown box of tricks that splits the signal so you have seperate tail, brake and indicators.
It all takes a bit of time and patience but I did it without using either the euro loom or tech2 and I've kept my red US lenses too.
Regards, Dave
To EU vette help!
