Sway bar install
Old Sep 25, 2019 | 06:46 PM
baxsom's Avatar
baxsom
Default Sway bar install
Ok dumb question. Does the sway bar center itself. I just replaced worn out bushings and endlinks and while it looks as centered as I can get it I didn’t read anything in any how to I could find about how to get it aligned correctly? Thanks
Old Oct 5, 2019 | 01:31 AM
jw1's Avatar
jw1
No, it does not. I use clamps to keep the bar from moving around
Old Oct 5, 2019 | 08:05 PM
davidfarmer's Avatar
davidfarmer
If your car is corner balance and level it will self center. If it is shifting then you need to corner balance and get adjustable end links
To Sway bar install
