Hi Guys n Gals Iv just had a new OEM harmonic balancer and bolt fitted by a garage but after getting it back i noticed that there is still a very slight wobble, nowhere near the same as before, but i didn't expect to see any wobble at all. If the the RPM is increased by a few hundred then the wobbling stops. Is this quite normal or should i be going back to the garage? Cheers
Why would you expect a different result when replacing a known bad part with the same bad part?In all those years GM never corrected the issue with their junk hb's.The issue is no fault of the shop that did the work
Mainly because my friend changed his HB for OEM and one year on it is still wobble less. Runs as straight as a die. So just looking for opinions on others who have replaced the HB with OEM and whether they have the wobbles.
Nobody replaces their HB with OEM around here so I doubt you're going to get any responses from anyone. It's well known here that HB wobble = new non OEM replacement. Not sure why you would replace a known badly manufacturerd part with the same thing.
Because not everyone lives on these forums and knows that all of the balancers are bad. Good lord, get off your horse and cut the guy some slack.
Keep an eye on it for a year. If nothing changes in that time, you will be alright for a long time. Its just going to wobble. As long as the belt dont chirp, dont worry about it..... Just a reminder to others......Powerbond/Dayco....PB 1117N--SS--Race....$260 Bucks, from Summit or Jegs.
First thing I do when there's a problem is research a solution. Researching hb wobble will lead most, if not everyone to this forum where it's said over and over to not use an OEM replacement part. 10 seconds of searching would likely have saved this guy guaranteed headache in the future.
First thing most people do when there is an issue is take it to their mechanic, listen to their advice, and have them fix it. Again, most people don't live on car forums.
Maybe the world you live in. For the most part if you own a corvette you likely have an appreciation for vehicles and will likely do most of your own work given you have the ability to do so. Also not sure why you keep bringing up that I must 'live on car forums'. Some quick research (which I assume you didn't do, probably didn't have a chance to to book an appointment yet) shows you are the one with a higher average daily post count than myself, so technically it is you who lives on the forum more-so than me (0.51 vs 0.49)
Besides what the forum engineers say IT IS NORMAL. It is not a solid piece it moves side to side forward and back. If you don't want to see it move forward or back put an SFI unit on. Power bond makes a nice one. My car got noticeably smoother
So what you did is squared up and kicked someone in the ***** for not knowing something that you demand that he should know.
Good for you. You must be proud of yourself. What does your research tell you about that? Surely you must have some statistic that you can cite for that?
Funny how another user basically said the same thing yet you didn't tell them to "get off his high horse". I understand it's hard for you to determine tone of voice via a forum post, but my intentions were not to demand he should know everything about a Corvette, moreso disbelief someone wouldn't do any sort of research on what they're spending their hard earned cash on when this is a highly reported problem. Sorry, I don't have statistics for people's feelings and the way some users react to posts that aren't meant any harm to begin with.
A couple of points:
1. I just had my HB replaced also and it has a slight wobble, nothing like it had before but you can see some movement.
2. The replacement HB was GM, I brought up the option of the other brands and the mechanic recommended I go with the stock HB. This mechanic, by the way, came highly recommended by the local Corvette club. So now the question is: do you go with something you read on the internet or do you go with a mechanic's recommendation. Right or wrong, I choose the mechanic's recommendation. In general I will choose stock parts for replacement on my vehicles.
I installed a new OEM balancer myself ten years ago. Wobbled a little bit, but not as bad as before, and never got any worse.
Back when C6s were new, you'd see cars at dealers with slightly wobbly balancers. Yours may get worse, but it probably won't.
My HB was bad and the belt squealed one year ago when I purchased my 2006 with 45,700 miles on it from MacMulkin Chevrolet. The car was a bit over the 30 day warranty. But the dealer supported me and replaced the HB , both serpentine belts and 4 wheel alignment. No cost to me. So of course they used an OEM HB. One year later, it is fine. Should be good for another 13 years and 45,000 miles. Just enjoy the car. No worries. People on this forum quickly condem and throw OEM parts like HBs under the bus.
The OEM balancer may last a long time, or it may fail in a short period of time .... it's just a 'crap-shoot' if it fails or not.
In my case, my OEM balancer was ok on my 2011 GS, but I still needed to have it pinned since I was installing a supercharger.
Since installing (or pinning) a balancer is a pretty big job that has a high labor cost, I could not justify pinning my OEM balancer and maybe have it fail sometime in the future ... So I had it replaced with a PowerBond Race Performance Harmonic Balancer (P/N: PB1117SS)
At least, now I have the secure feeling that I won't need to go in there and replace it again any time soon (if ever).
Bottom line .... The OEM harmonic balancer certainly does not have a very good 'track record'. If the OEM balancer ever needs to be replaced, I just can't see installing another failure prone OEM balancer.
Replaced my OEM wobbler with this unit and ARP bolt. Highly recommend this!
