2007 Z06 Starter?
Old Oct 5, 2019 | 12:11 PM
Alans1225's Avatar
Alans1225
Default 2007 Z06 Starter?
Looking for some opinions here. . .
I have a 2007 Z06 that has Kooks LT Headers, Black Widow R Cam, as well as a few other modifications. I've had the car for over 3 years without any issues, until now...
Lately, the car has had issues starting back up after driving it long enough to warm the engine. Here's an example: The car will start just fine as long as it is a cold start, no hesitation at all. However, if I turn the car off after the engine has warmed up, the car will struggle to turn over to start and if it does, the car will sometimes go into a "limp mode" where I lose power steering and my tachometer. After I shut the car down, and let the car cool off for approx. 30 min to an hour, the car will start just fine without any issues at all. I am thinking that I need to replace the starter, however due to the fact that the car starts just fine on every cold start, it makes me second guess the purchase. I have also purchased a heat shield for the starter that I plan to install next week to see if that corrects the issue. Maybe the starter is becoming too hot from the headers and the heat has worn on the starter for some time now?
Anyone else have any ideas or maybe had a similar issue? Looking for some advice here.
Thank you,
Alan
Old Oct 5, 2019 | 03:54 PM
baxsom's Avatar
baxsom
Seems very common for these cars with headers. I went to a power master starter to fix it when mine started doing this
Old Oct 5, 2019 | 07:33 PM
Sox-Fan's Avatar
Sox-Fan
As did I, and haven't looked back.
Old Oct 5, 2019 | 07:39 PM
farmington's Avatar
farmington
Might be as simple as cleaning and tightening cables going to starter.
Old Oct 5, 2019 | 07:46 PM
jaybee924's Avatar
jaybee924
What headers are you running?
Old Oct 5, 2019 | 10:31 PM
Alans1225's Avatar
Alans1225
Looks like I'll order one. thanks for the heads up!
Old Oct 5, 2019 | 11:47 PM
Sox-Fan's Avatar
Sox-Fan
Kooks.
Old Oct 5, 2019 | 11:53 PM
Sox-Fan's Avatar
Sox-Fan
Look, cleaning the terminals won't do it. the solenoid has a baklelite endcap where the main power stud is attached. Over time the heat deteriorates that and the main stud becomes loose like a loose tooth when the car is hot. Search here on the forums and you'll find a number of threads about it. You can replace the solenoid and it will be fine again for a time. Wrapping it is useless. Might take longer to heat the solenoid up but then it holds the heat in. I put a Powermaster starter in because it doesn't have a bakelite endcap on the solenoid. Have not had an issue since.
Bear in mind that you do have to cut one terminal off the starter wire harness and solder a ring connector on if you go that route.
Old Jan 4, 2020 | 09:36 PM
angeldog's Avatar
angeldog
Default Hard starting ls7
Yep replace with powermaster worked for me
Old Jan 4, 2020 | 10:13 PM
baxsom's Avatar
baxsom
Power master here. Had to do a sight clocking of the body and trim the inspection plate plastic but good to go
Old Jan 4, 2020 | 11:08 PM
new 2 me's Avatar
new 2 me
Power master starters need a bit of custom fitting or would they be a direct replacement when running stock exhaust? (2010 Ls3 A6)
Old Jan 6, 2020 | 03:45 PM
bravo29's Avatar
bravo29
Replace starter and heat shield it. If you buy a el cheap O one buy a heat shield or Heat wrap for the starter.
Old Jan 7, 2020 | 04:10 AM
American Heritage's Avatar
American Heritage
Supporting Vendor
Power master is the way to go for sure!
Fits much better than the MSD starer
https://americanheritageperformance.com/
To 2007 Z06 Starter?
