How to break in new engine?
This is from GM crate motor instructions from my LS7
Start-up and Break-in Procedures: Safety first, if the vehicle is on the ground, be sure the park brake is set, the wheels are chocked and the car cannot fall into gear. Verify everything is installed properly and nothing was missed.
1. This engine assembly needs to be filled with oil. After installing the engine, ensure the crankcase has been filled with the appropriate motor oil to the recommended oil fill level on the dipstick. These crate engines require a special oil meeting DEXOS1 - 5W30. Also check and fill as required any other necessary fluids such as coolant, power steering fluid, etc.
2. This engine MUST be primed with oil before starting. The use of Kent-Moore engine preluber kit J45299 is the preferred process for priming. Note: A constant and continuous flow of clean engine oil is required in order to properly prime the engine. Be sure to use approved engine oil, as specified.
3. Start the engine and listen for any unusual noises. If no unusual noises are noted, run the engine at approximately 1000 RPM until normal operating temperature is reached.
4. When possible, you should always allow the engine to warm up prior to driving. It is a good practice to allow the oil sump and water temperature to reach 180°F before towing heavy loads or performing hard acceleration runs.
5. The engine should be driven at varying loads and conditions for the first 30 miles or one hour without wide open throttle (WOT) or sustained high RPM accelerations.
6. Run five or six medium throttle (50%) accelerations to about 4000 RPM and back to idle (0% throttle) in gear.
7. Run two or three hard throttle (WOT 100%) accelerations to about 4000 RPM and back to idle (0% throttle) in gear.
8. Change the oil and filter. Replace the oil per the specification in step 1, and replace the filter with a new UPF48R AC Delco oil filter. Inspect the oil and the oil filter for any foreign particles to ensure that the engine is functioning properly.
9. Drive the next 500 miles (12 to 15 engine hours) under normal conditions. Do not run the engine at its maximum rated engine speed. Also, do not expose the engine to extended periods of high load.
10. Change the oil and filter. Again, inspect the oil and oil filter for any foreign particles to ensure that the engine is functioning properly.
First 50 mi get the rings seated dont baby it nor beat on it. Dump oil and progressively have more fun
I woulndt worry about it really. Lots of failures are the owners fault by showing off, revving the pee out of it (esp cold) donuts etc. There is simply no benefit to babying things for 500 miles 1975 has come and gone.
Start up, drive to the highway, rev/accelerate and coast a few times......take it back to the garage (maybe 30 to 50 miles of driving), change the oil......and done!
The only thing that matters with a HR valvetrain is seating the rings. Everything else is just BS.
KW
I used to prime my engines many years ago but now all is different mixing 50% Castrol GTX 10 w 30 and 50% Lucas non Synthetic oil Stabilizer so I don’t need to worry about priming cause that stuff clings and stays in place I use it on all bearings both Pushrod ends and rockers so when I’m done my engine is ready for me and scared for no-thing.
