strange message on driver display
Old Oct 21, 2019 | 03:25 PM
ZRon1's Avatar
ZRon1
Default strange message on driver display
Ok here is a strange one. 2011 ZR1, getting a message : Engine Hot A/C off- I have checked the engine temp with a temp gauge and all is normal. Tried clearing message with battery disconnect but it comes back. Dealer (ha!) claims never seen this message before. No trouble codes are thrown. Any ideas??
Old Oct 21, 2019 | 04:44 PM
87SAM's Avatar
87SAM
What is the temp as read on the DIC?
Old Oct 22, 2019 | 12:41 PM
ZRon1's Avatar
ZRon1
When this message appears, the temp gauge on the dash goes to zero, as if the car were off. The A/C indeed does not work when this message appears. Using an infrared temp tester the engine shows 199-200 degrees and very little difference in pre thermostat and post thermostat readings. The closest dealer, Classic Chevrolet as I said does not have a clue but wants to charge me $100 plus to do a "diagnostic test". My fear is that they will simply disconnect the battery like I did and the message will go away and tell me it is "fixed". Then as I said, after a couple of start/stop cycles, the message will come back! I bought this car new and this is the ONLY issue I have ever had. Driving me crazy. As you may know, the ZR1 does not use a coolant sensor so a simple replacement is a no go. Thanks for your insight.
Old Oct 22, 2019 | 02:16 PM
87SAM's Avatar
87SAM
Sounds like a possible bad temp sensor, or wiring to it. I think this message also sets a code which would also help point you in a direction.
Old Oct 22, 2019 | 02:33 PM
ZRon1's Avatar
ZRon1
Thanks for your response. The ZR1 does not have a temperature sensor in the traditional sense. It uses a variety of inputs to determine the engine coolant temperature (according to factory service manual). No codes are set when this message shows up. I found one other member who reported this same message in 2017 so I am hoping to hear back from him.
Old Oct 22, 2019 | 03:03 PM
87SAM's Avatar
87SAM
Interesting
Old Oct 23, 2019 | 10:56 AM
luka2sb's Avatar
luka2sb
I was curious about your comment that the LS9 doesn't have an engine coolant temp sensor.
i think it does, I think it should be in the head, above cylinder 1. kind of seems like it should be a few inches above the cylinder 1 spark plug. personally i would start by replacing that sensor, or at least checking the connector and wiring for problems.
EDIT: read diagnostic trouble codes, even if the check engine light is off, that doesn't mean that it didn't log something in history.
Old Oct 23, 2019 | 11:02 AM
irok's Avatar
irok
I believe that message is related to data received from your HVAC control module.I had the message appear on DIC at least once but it cleared on its own.I have never had an issue with my HVAC control module but I think I may have read on here where others on here have had this issue when HVAC module was failing
Old Oct 26, 2019 | 12:36 PM
wjnjr's Avatar
wjnjr
Originally Posted by ZRon1
Thanks for your response. The ZR1 does not have a temperature sensor in the traditional sense. It uses a variety of inputs to determine the engine coolant temperature (according to factory service manual). .
Actually, it does. Located at the front of the driver's side head near the no.1 spark plug. Same as every other LS motor
Problems with the temp sensor or it's connector and/or related wiring can cause erratic temp readings and trigger error messages. The clue is an erratic temperature gauge.
Old Oct 27, 2019 | 05:20 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Ok here is a strange one. 2011 ZR1, getting a message : Engine Hot A/C off...
The engine temp sensor on the front of the left cylinder head is bad or disconnected.
Tom
To strange message on driver display
