Engine Shut Down
Old Oct 24, 2019 | 10:54 AM
Bryan Melton's Avatar
Bryan Melton
1st Gear
Default Engine Shut Down
I have a 2008 LS3. When it is driven in hot weather (90 degrees +) the engine will shut down for 10 to 15 seconds and start back up on it's on. After about 1 to 2 minutes it will shut down again. Manual transmission, leaving the clutch out. it will do this until you park it and shut it off. It has been tuned. It leaves no codes for diagnostic tech to correct. Any ideas would be helpful.
Old Oct 24, 2019 | 12:41 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
With heat comes electrical resistance...I'd take it to a Tech that has a DSO (scope) and hook it up and see what's dropping out....maybe fuel pressure, crank sensor signal etc...
