Degreeing Cam
Old Oct 24, 2019 | 11:15 AM
Ekroeger2006's Avatar
Ekroeger2006
Default Degreeing Cam
Biggest question I have, is can you degree the cam while engine is in the car? I didn't want to have to drop it, if at all possible. I figured spending an extra hour or so making sure everything is correct is worth it rather just buttoning it up dot to dot. Any info or tips would be helpful, thank you
Old Oct 25, 2019 | 08:59 AM
new 2 me's Avatar
new 2 me
Bump for cam degreeing
no experience with Ls motors, but back in the day when we built dohc motorcycle engines degreeing the cams made a big difference. We were even getting stock cams to perform by changing their positions
if if I were doing a cam on my car I would want it in recommended time in relation to the crank
Old Oct 25, 2019 | 10:47 AM
irok's Avatar
irok
You can't degree in the cam without an after market cam gear kit,best you can do is dot to dot without it
Old Oct 25, 2019 | 07:35 PM
jonjoy's Avatar
jonjoy
in the car almost impossible, if you chose a good cam Co. you'll be golden dot to dot, new Melling oil pump is not a bad idea while your there, C5R chain too
Old Oct 25, 2019 | 07:40 PM
Ekroeger2006
I have adjustable aftermarket timing set already. And I was hoping there would be enough room but may just do dot to dot if I absolutely have to. Melling won't help me, I have a dry sump motor. Appreciate the responses so far
To Degreeing Cam
