HELP: Rear leaf spring broke in half
Old Nov 15, 2019 | 07:22 AM
Mr.ReesesPieces's Avatar
Mr.ReesesPieces
Cruising
Default HELP: Rear leaf spring broke in half
Soooooo I went to leave for work yesterday morning and car wouldn't move (Note: I arrived home Wednesday night with no issues and did not leave the house). Thought at first maybe I was in 5th instead of reverse, nope. Check my e-brake and its down. Got a flashlight, took a look under the car and BAM I can see the leaf spring had snapped. All I can say is I'm thankful it didn't happen while I was driving, but how THE F*** does this magically happen while the car was parked during the night? I saw a thread about someone having their dumps close to the rear causing excessive heat and possibly causing failure, but I'm running full exhaust all the way to bumper.
My car is a 2013 base M6. Would a z51/z06 leaf spring make a difference? If anyone has one lying around I'm ready to buy ASAP as this is my current daily, or if you know a good gm parts supplier I will buy a new one today. Waiting to hear back from gmpartsdirect.com about being in stock, but if you know a place to use please let me know and will call right away.
Thanks ahead of time,
Jesse.
Old Nov 15, 2019 | 10:08 AM
ttx350z's Avatar
ttx350z
A location would help to see if someone is local...
Z06 and Z51 will be a little stiffer.
Old Nov 15, 2019 | 10:41 AM
Mr.ReesesPieces
Cruising
Thanks. Located in S. Florida, but wouldn't mind paying someone to ship. Know of a reliable GM parts store that will actually get back to you?
Old Nov 15, 2019 | 10:46 AM
Sox-Fan's Avatar
Sox-Fan
Call Cultrag. They are a forum vendor. Speak with Patrick. He's very responsive. If you get the machine leave your name and number, he has always called me back.
484-334-8833
https://www.cultragfactoryparts.com/
Old Nov 15, 2019 | 11:16 AM
Mr.ReesesPieces
Cruising
484-334-8833
Much appreciated! Called Patrick and got it ordered right away. Good guy to deal with, thanks!
Old Nov 15, 2019 | 11:29 AM
davidfarmer's Avatar
davidfarmer
Wow, I’ve seen cracks with trauma, but never broken through. Good luck
Old Nov 15, 2019 | 11:32 AM
torquetube's Avatar
torquetube
Jesse.
Are you sure the spring has failed? Your rear suspension should be slammed like the trunk was filled with anvils. You don't mention noticing this, which is the reason I ask.
GM warns against using powerful cleaning agents on or near the spring, presumably such as strong acids or solvents.
Old Nov 15, 2019 | 11:45 AM
Mr.ReesesPieces
Cruising
Positive its the leaf spring and the rear tires certainly are TUCKED like its loaded down. Have not used any strong cleaners around or under the vehicle.
Old Nov 16, 2019 | 05:40 PM
jonjoy's Avatar
jonjoy
actually ZO6 and base are the same in the rear
Old Nov 17, 2019 | 12:26 AM
Dano523's Avatar
Dano523
On the transversal spring, could be factory defective part, or would bank that someone was using a chemical wheel cleaner on the rims, got it on the trans spring without flushing it off (to let the cleaner have it way with the composite part) , and what caused the spring to fail instead.
Old Nov 17, 2019 | 01:42 AM
C5Natie's Avatar
C5Natie
C6 rear spring rates,
Base: 657lbs
Z06: 782lbs
Old Nov 17, 2019 | 01:45 AM
C5Natie's Avatar
C5Natie
The spring could have been damaged somehow. You’ll be able to better tell after you pull it out. Do you raise the car by the rear cradle and maybe lifted it by the spring by accident? Good thing it didn’t fail as you drove!
Old Nov 17, 2019 | 02:40 PM
WW7's Avatar
WW7
If you have a base C6 and replace just the rear spring with a Z51 or Z06 rear spring, your car will handle like crap and possibly be very dangerous to drive when pushing it...These suspensions are balanced ,so putting a heavier spring on just the back will throw your suspension balance off ....These aren't old 60s Chevys where you can just mix and match parts with good results....WW
Old Nov 18, 2019 | 07:10 AM
Mr.ReesesPieces
Cruising
I do not. I have the pucks to lift from the side and always cautious when placing jack. Certainly would of crashed/got into an accident if it happened while driving, so i'm grateful it occured after I parked.
Originally Posted by WW7
If you have a base C6 and replace just the rear spring with a Z51 or Z06 rear spring, your car will handle like crap and possibly be very dangerous to drive when pushing it...These suspensions are balanced ,so putting a heavier spring on just the back will throw your suspension balance off ..When taking a hard rough corner the front will be bouncing at one rate and the rear will be bouncing at another rate....Even if you replace both springs with Z06 springs, you should then probably replace all your shocks with the B8 shocks instead of the stock shocks that come on the base model...These aren't old 60s Chevys where you can just mix and match parts with good results....WW.
Thanks for the heads up. I ordered the base spring just to be sure nothing would be off.
Old Nov 18, 2019 | 08:57 PM
tw78911sc's Avatar
tw78911sc
my 07 Z06 had the front one cracked abut 1/2 way through. Replaced with coil overs, you can have my rear if you pay packing/shipping
To HELP: Rear leaf spring broke in half
