2012 GS Infotainment system issues
Old Nov 18, 2019 | 06:15 PM
SCOTTSEM's Avatar
SCOTTSEM
1st Gear
Default 2012 GS Infotainment system issues
My infotainment system has worked perfectly since I bought the car 7 years ago. It worked fine this morning, however when I started the car up after work the screen on the infotainment system is blank white. Tried turning the car on and off several times but that did not help.
Might be coincidental but I replaced the battery 2 weeks ago.
Old Nov 18, 2019 | 07:18 PM
4SUMERZ's Avatar
4SUMERZ
They tend to be finicky at times. Did you check the fuse to see if it was OK.
You can try disconnecting the battery again, and it might reset whatever electrical glitch it has.
Good Luck
