I just picked up a couple of cases of Mobil 1 Oil at Costco for $23.69 6qt case. Only problem was they do not have 5W 30 in regular Mobil 1 Synthetic only only Synthetic High Mileage version. My car has just C6 has just 8500 miles. Does anyone think that will be a problem? This is the oil for 75,000 miles plus cars. not the super extend change interval oil.
Any thoughts on this?
Barrier
Using this oil will not do any damage to your lower mileage C6. The high mileage version has a few additives and conditioners that the regular synthetic oil does not.
The additives and conditioners help to curb oil consumption and help worn seals so oil leaks don't form. It also helps prevent sludge build up and reduce wear.
