2010 Base - Issues
Newer to the forums. Bought the car back in June, with 62k miles on it.
Replaced spark plugs (AC Delco), and wires (Taylor)
Mods:
-Vette-Air scoop
-CAI - which I removed, and put stock back on due to surging
-Catch Can
-Magnaflow Axle back mufflers
Issues that have developed over the past month:
-Rough Idle at 500rpm, with rare shudder, like it's about to die, but doesn't.
-low popping sound in exhaust
-Fuel consumption is up
-Some hesitation when hitting it hard, with rare stalling.
-Exhaust had the sulfur smell for it brief time
I checked all the basic stuff for peace of mind. No smoke from exhaust. No milk in the coolant. No milk in the oil, totally clean. No huffing from the oil fill (very slight suction actually).
I have taken it to a shop that specializes in Vettes. Had random misfire codes. They did a resistance check on the injectors...all good. They had a set of coil packs, and swapped them out to test. No change. They ran some scope, and said all the cylinders were firing. Replaced the upstream o2 sensors for grins, no change.
Frustrated as hell. Never get a CEL, except for the occasional tire pressure monitor, which needs to be replaced.
Throttle body issue?
ECM?
Mods:
-Vette-Air scoop
-Catch Can
ECM?
If you knew someone that had a similar Corvette, you could borrow his just to see if fixed the problem .... easy to swap out
ACDelco P/N: 2134222
$38.42 with free shipping
