Driver door won't open
Old Dec 12, 2019 | 05:28 PM
GS Corvette's Avatar
GS Corvette
Default Driver door won't open
So I have read all the threads about this issue and none are like the issue I'm experiencing.... when the door is closed and I try to open the door the window does it's thing, you hear the latch release but the door won't open....I swapped the door pads and that's not it... I think it's the latch but it doesn't do it all the time...Plus when the window is down... the door functions correctly every time. I have tried disconnecting the battery and touching the positive to the negative to drain all the residual energy out and to no avail.
I'm stumped because when the window is down it works fine so I don't want to go through the hassle of replacing the latch just yet...
Any help with this it would be greatly appreciated.
Thank you.
Old Dec 12, 2019 | 06:57 PM
Phil F. Wier's Avatar
Phil F. Wier
Does the lever on the floor open it? Mine did the same and I just used that lever until it started working again. It turns out I was not using pulling pressure when I used the electronic openers. I think it gets a little dirty on the inside mechanism and the manual override sort of cleans out the trouble spot after a few days and then if you apply pressure when you use the handles, it seems to stay fixed.
Old Dec 12, 2019 | 07:00 PM
GS Corvette
Yes the lever on the floor opens it... so does the trunk one, but the door works fine when the window is down... which is something different than everything I've read.
Old Dec 12, 2019 | 07:36 PM
maverickmk's Avatar
maverickmk
Maybe the window is catching on something. Look for any witness marks all around the window area. Have you tried to give it a stern pull with the window up?
Old Dec 13, 2019 | 12:46 AM
Cherokee Nation's Avatar
Cherokee Nation
Does it open with the button to get out?....If so it's not the latch in the "B" pillar.
Old Dec 13, 2019 | 10:42 AM
GS Corvette
The door does opens perfectly from the inside with the window up or down, from the outside it only works when the window is down. I have also tried resetting the window memory and still have the same issue.
This one is weird, I can't seem to figure this one out just yet.
Old Dec 13, 2019 | 10:43 AM
GS Corvette
Checked the window, it's working perfectly and not catching on anything.
Old Dec 13, 2019 | 12:43 PM
maverickmk's Avatar
maverickmk
Hmm, that's really strange. I'm out, I hope you can figure it out.
Old Dec 13, 2019 | 12:50 PM
GS Corvette
I hope so too.... I'll post anything I find cuz this one is a strange one.
Old Dec 17, 2019 | 12:18 AM
Cherokee Nation
OK....Back to the drawing board......Good Luck and come back with the fix.....IF?
Old Dec 17, 2019 | 12:20 AM
GS Corvette
It was the latch... bought a new one, installed it in 15min good as new.
Old Dec 17, 2019 | 01:09 AM
Cherokee Nation
Which latch?
Old Dec 17, 2019 | 01:11 AM
GS Corvette
Which latch?
The main one on the B pillar which can also be controlled manually with the handle and cord in the trunk.
Old Dec 17, 2019 | 11:29 PM
Cherokee Nation
Which latch?
My 08 does not open from the outside or the inside and i checked for a signal at both and all checked ok....I looked at the latch at a few GM parts places online and they show two different parts numbers?..What is the part number on the one that you got...Thanks
Old Dec 17, 2019 | 11:36 PM
GS Corvette
GM#88956758 I have a 2010 GS
Old Dec 17, 2019 | 11:49 PM
Cherokee Nation
To Driver door won't open
