Header Gaskets on LS
Old Dec 22, 2019 | 01:37 PM
Randy Firor's Avatar
Randy Firor
Default Header Gaskets on LS
Installing new header system on my C6. Last time I did headers on my old LS1 I just re-used the metal, multilayered, stock gaskets and they worked fine. I'm installing speed engineering stainless steel headers and they gave me some of those metal lined felt or something, not sure, but they look almost perforated on the metal and are thick, like maybe a 16th of an inch. Should I use them or should I just re-use the stock ones? Might sound like a dumb question but I hate header leaks!!
Old Dec 22, 2019 | 06:26 PM
BigBlok502's Avatar
BigBlok502
I bought my Kooks headers used and reused my factory gaskets, four years later still no leaks.
Old Dec 22, 2019 | 07:26 PM
SixAddict's Avatar
SixAddict
I also went with the Speed Engineering headers and the shop that installed them had three choices to make with the gaskets I provided, they went with my OEM ones and I haven't had an issue in two years now.
Old Dec 22, 2019 | 07:29 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
I would reuse your stock gaskets over the Speed Engineering provided gaskets. Even with the crusty appearance.
That being said if you have the time it looks like they have some miles on them so some fresh factory multi layers would be nice.
Old Dec 22, 2019 | 10:11 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
I will repeat what everyone else has said .... The best gaskets are the stock header gaskets.
And I will also say ... Use the stock exhaust manifold bolts too.
Buy new, if you feel the need, but use OEM
Old Dec 22, 2019 | 10:12 PM
maverickmk's Avatar
maverickmk
Those are FelPro gaskets. I would use those before reusing old ones.
Old Dec 23, 2019 | 08:49 AM
Fly N Low's Avatar
Fly N Low
I have always used new OEM gaskets and OEM bolts. Clean the loctite off the bolts on a wire wheel and then use a small dab of anti seize on them. You will need to re torque after the first couple heat cycles. Never had a leak or a loose bolt.
Old Dec 23, 2019 | 10:51 AM
Nursing Nevada's Avatar
Nursing Nevada
reuse your stock gaskets and lather with copper spray. The dozens of times I've removed manifolds and such, has always worked great
Old Dec 24, 2019 | 06:11 AM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
So , with all the money you spend on Headers you want to cheap out with old gaskets? Buy a New set of OEM.
Old Dec 24, 2019 | 12:04 PM
Mr. Black's Avatar
Mr. Black
It's not about being cheap. They've been proven to reusable with 100% reliability if they're undamaged on removal since the invention of the LS1 engine.
To Header Gaskets on LS
