C7 Upper Control Arms on a C6?
Like many people have experienced with the C6 upper control arms, mine are starting to slide out of the bushing. This car was run hard by a previous owner doing autocross. I'd like to replace them while I install DRM shocks, and have considered a few different routes:
- Replace with OEM C6 UCA's ($284)
- Install Global West KT-C56F Del-a-lum kit ($790)
- See if C7 UCA's will work ($190)
My main reason for researching this is:
- My car is only street driven, so the Global West kit at $790 is probably overkill, although it will hopefully tighten up the pretty loose and unsettling suspension (fixes LCA bushing deflection as well).
- I want to save money, and the C7 UCA's (at ~$190) should not have the same problem that the C6's have.
Popular Reply
I measured both the left and right control arms, and it resulted in them being slightly different caster wise, they were pretty much exact camber wise. I could chalk this up to the bushings not being centered possibly? When I measured the C7 control arm, it was dead center between the two. Any slight difference in caster can easily be resolved through an alignment.
The only concern here is the resting height of the arms. Both left and right C6 arms had a much lower resting height than the C7's. And actually, I'll have to mock it up in the car, but it seems the C6's would cause strain on the bushings at ride height, where as the C7's would be less stretched (or twisted?) at ride height. And if the control arms are in fact functionally the same, why would GM just replace the C6's with the C7's in the catalog? And other than the elongated holes on the dog bone mounts being on opposite sides, why would GM have two different parts for each side?
Anyways, here are the pics:
Bill
You can just buy the bushings you need a la carte from this supporting vendor, https://www.borgmotorsports.com/coll...idual-bushings
I actually just noticed that the previous owner had done the modification to reverse the rear bushing in each one.
Mine came from the factory with the metal flange on the outside of either bushing. This captures the arm between the bushings.
Every other upper arm I've seen is the same way.
Yours have the flange on the same side of both bushings, so the arm can shift backwards.
I'm going to order another C7 upper control arm, install them, and consider it done. If this wasn't just a street car, I'd go a different route.
I bought my car new in 2006 and the T1 arms have been on for almost 10 years with no bushing issues.
C5 arm on top C7 on bottom. You can see how there is less bushing on the outside plus a large flange face to keep arm from moving as far.
Installed. Bolted right in with no issues.
$98ea from RockAuto and arrived in a week. Beats the CRAZY prices people want for C5 arms
JonnyCap and smitty2919: Have either of you had an alignment since installing? Any problems?
