C6 ZR1 Shift/Tranny issue
Old Jan 4, 2020 | 04:57 PM
JeremyMalin's Avatar
JeremyMalin
Default C6 ZR1 Shift/Tranny issue
Back story, I was racing down open freeway in the 190mph range in 6th. All of a sudden, the car started losing speed and rpm's went up. As I slowed I shifted to 4th and everything seemed fine. Shifted back to 6th and there was no gear. Realized I had no gears at all other than 4th. I have an MGW shifter and can feel it shifting in to gears from the shifter it's self, but nothing out of the transmission. No funky odor, a week old clutch fluid change. I figure I should check linkage first. I know there is an adjustment under the shifter itself that can come loose. Is there another one under the car by the transmission?
Old Jan 4, 2020 | 06:13 PM
JeremyMalin
I did take the shifter out and went back through the alignment procedure. Still no dice. Have 4th but that's it.
Old Jan 7, 2020 | 12:41 AM
Dano523's Avatar
Dano523
Here you go, and notice that only one gear is direct from input shaft on the left, to output shaft on the right when engaged, with the rest of the gears are through the secondary shaft instead.
Old Jan 7, 2020 | 04:01 AM
American Heritage's Avatar
American Heritage
Supporting Vendor
Dano523 is saying you broke something inside your transmission and I would agree.
https://americanheritageperformance.com/
Old Jan 7, 2020 | 10:14 AM
JeremyMalin
At this point, the best case scenario is the roll pin to the shift linkage broke. This is going to be above my understanding so back to the race shop it goes.
Old Jan 11, 2020 | 12:12 PM
RickCC6's Avatar
RickCC6
any updates yet?
Old Jan 11, 2020 | 02:07 PM
sccaGT1racer's Avatar
sccaGT1racer
That thing should be making some nice noises. Pull the drain plug you should find some chunks.
Old Jan 11, 2020 | 04:36 PM
JeremyMalin
No noise.
So both of the linkage collars are fine. Next is to drop the tranny and look under the top plate to see if I broke the roll pin. I'm not doing this so off to the race shop it goes. Hopefully I will have a solid idea by this time next week.
To C6 ZR1 Shift/Tranny issue
