C6 turn signal problem
Old Jan 14, 2020 | 08:52 PM
Matthew Awdish's Avatar
Matthew Awdish
Default C6 turn signal problem
Hi, I have a 2012 corvette base, I recently installed aem wideband (yesterday) I ran the wire thru the fender liner and up behind the battery on passengers side, there is a rubber grommet where the lines go to the fuse box, I ran it thru there (I know I shouldn’t have but I used a box cutter to cut the grommet a little to get it thru, I also used a screwdriver to help push it thru. As I have it done now, I started the car up and well my turn signal blinks fast, and the front signal doesn’t work. I changed the bulb and nothing, I think there is a chance I damaged a wire while trying to run the wideband wire thru that grommet, how should I go about fixing it? Should I try removing the whole grommet and maybe try and pull the wires out a little to inspect?? I’m really at a loss of what to do please any help would be appreciated!
Old Jan 17, 2020 | 09:33 AM
rc51racer's Avatar
rc51racer
I would start with pulling apart wires where the grommet was cut and inspecting for cut or 2 bare wires touching. Has to be in that spot where the repair is needed. Hyper flash blinkers are annoying. I had that for a bit when I installed LED switchbacks a few months ago until I installed a relay.
Old Jan 17, 2020 | 03:02 PM
Matthew Awdish
thank you, I ended up finding the wire in that bundle that was cut, I was going to try it myself but it is such a hard spot and such a small wire I just went to my friends shop and they got it back together and wrapped it all back up in less than 20 minutes free of charge, happy I was able to get it done so easy!
To C6 turn signal problem
