Coil overs
Old Jan 15, 2020 | 08:53 PM
Dabbreath's Avatar
Dabbreath
1st Gear
Default Coil overs
If I put adjustable coil overs on my base do I eliminate the composite leaf spring in the front or does that stay or is it optional to keep or not
Old Jan 15, 2020 | 09:28 PM
tw78911sc's Avatar
tw78911sc
pull them off, not sure Id only do one end of the car, ride hgt and spring rates may be out of whack.
Old Jan 15, 2020 | 10:01 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Coilovers replace the leaf spring ... remove it
Old Jan 16, 2020 | 06:47 AM
DaOtherOne's Avatar
DaOtherOne
Old Jan 16, 2020 | 10:02 AM
PCMusicGuy's Avatar
PCMusicGuy
There is only one coil-over kit that I know of (Eibach) that is designed to keep the factory leaf springs. All others want you to remove them.
To Coil overs
