Brake pads dragging HELP
Old Jan 18, 2020 | 08:05 PM
db2xpert's Avatar
db2xpert
Default Brake pads dragging HELP
Friends car at racetrack today.
Experience racer, and darn good mechanic.
2008 Z06
New front pads, and new stock calipers. New pins.
New rotors
Complete brake flush, excluding Tech 2 cycling of abs
Had a fulll ABS bleed maybe 3 months ago, not related to current issues, just because friend was there with snap on too, that could cycle ABS>
First problem about a month ago, in a race the pedal suddenly went to the floor and no brakes.
Everything a bit old, so all new parts as above.
His first run today, pedal goes major spongy after a couple of laps... comes in and front brakes are cooking.
Pads are dragging.
Brake bleed, no help. Still dragging, as can't turn the rotor by hand - both front wheels.
Pulled the new pads, put in old 1/2 worn pads.
Still the same.
Put the old caliper back one with the old pads, still the same, after brakes have been applied, pistons not retracting into calipers.
Pedal goes 1/2 way to floor, spongy, but can pump it up where the 1/2 way point is firm -- of course rotor can't be turned by hand.
Had scanner on the car, no codes for anything.
So -- master cylinder ? ABS?
Engine not running, so not power booster.
Old Jan 19, 2020 | 01:23 PM
irok's Avatar
irok
caliper's not installed upside down on wrong side of car are they?
Old Jan 21, 2020 | 12:05 AM
db2xpert's Avatar
db2xpert
LOL
Figure it's the master.
Easy replacement, except for needing a tech2 to cycle the abs.
Old Jan 21, 2020 | 07:20 PM
corvettejoe09's Avatar
corvettejoe09
I wish I could help you, sorry. It seems to be a rear issue. I never heard of anything like this. I'm wondering if it's electrical rather than mechanical.
To Brake pads dragging HELP
