New airbag module, need Tech II help
I replaced the airbag module and took it to the dealer to be 'married' to the car. The dealer tech is saying the tech II will not see the airbag module. I'm trying to tell them that the BCM needs to be updated with the code from the new airbag module before the BCM will 'see' it.
I have no idea how a Tech II works. Can anyone explain how to use a Tech II to update the BCM with the code from the new airbag module so I can point them in the right direction?
Thank you!
Scott
2006 Corvette
Good luck with your repairs.
