Header help
Old Feb 1, 2020 | 11:52 PM
Matthew Awdish's Avatar
Matthew Awdish
Default Header help
I have a 2012 corvette base ls3 and I installed longtubes and x pipe from speed engineering and well my o2s melted so I’m taking to headers off, heat wrapping them and also heat wrapping the o2 extensions. I have the car up on jack standsand ramps, the plug wires are off and the driver side header is unbolted, every clamp is in done and so are spring hangers, I CANT seem to get the damn headers out of the x pipe. I’ve tried taking the exhaust apart and I can’t get it off anywhere else either, I don’t have access to the back of the car right now as I have the garage closed and it’s 2 cm from the garage door (the other side of the door is 3 feet of snow lol) so I don’t wanna remove mufflers fully off the car if I don’t have to, any help at all would be great! Thanks
Old Feb 2, 2020 | 05:41 AM
Boostedsvt's Avatar
Boostedsvt
If I were doing the job I would want my headers bolted to the head while trying to remove the x-pipe. If you can reattach the one that’s off without damaging the threads in the head for the header bolts it may make it easier for you. Good luck!
Old Feb 2, 2020 | 04:16 PM
SixAddict's Avatar
SixAddict
Would leave headers bolted up then remove x pipe from mufflers tailpipe or from headers.
I'm also running the speed engineering setup but the one exception I made was to go with 31 inch 02 extensions instead of the 24 inch they offer. The longer the better, I was able to get the wiring far away without wrapping anything.
Good luck.
Old Feb 4, 2020 | 07:31 PM
Raffman55's Avatar
Raffman55
2024 C6 of the Year Finalist - Modified
2018 C1 of Year Finalist
If your talking rear O2 sensors I would plug them and have a tuner shut them off.
Old Feb 5, 2020 | 10:43 PM
xBoostx's Avatar
xBoostx
x two here only use the front ones.
To Header help
