08 Base radiator change
Old Feb 5, 2020 | 08:22 PM
07z51Red's Avatar
07z51Red
Navigator
Default 08 Base radiator change
So I haven't done a radiator since my 1990 Beretta 🤣. That being said, do I need to do anything further regarding the trans fluid? Do I need to back fill the radiator before connecting the top trans line? Or should I just let the trans pump refill it and add fluid to the trans later?
Old Feb 5, 2020 | 09:19 PM
Vettelet's Avatar
Vettelet
Do I need to do anything further regarding the trans fluid?
-No, maybe elevate line so it doesn't dribble on floor or if you have some nice caps for it plug them. The amount of fluid lost is trivial if you are careful, just check level when done...doubt the internal cooler holds much.....that being said be CAUTIOUS to not tip radiator ports DOWN because all of the coolant and trans fluid in it will dump all over.
-No...
Should I just let the trans pump refill it and add fluid to the trans later?
Yes
Welcome to the forum.
Old Feb 5, 2020 | 09:38 PM
07z51Red's Avatar
07z51Red
Navigator
Thank you very much! I'm sure I'll be back for more nagging questions. After doing a thorough search of course...
To 08 Base radiator change
