Cam selection please help!!! Ls3 m6
I currently own a 2009 corvette m6 & I am wanting to add some more power. The car is mostly a weekend car but I do drive it to work every once in a while. The cars mods as it sits are Texas speed 1 7/8 headers with 3” x pipe & a Halltech Mf103 cai. It made 429/422 after being tuned. My goals for the cam is to track it, be pretty aggressive nothing insane, and be street friendly if possible. Would like to be 470-490 wheel horse power after being tuned.
Here are the cams I’ve been considering.
LG Motorsports/ G6x3 Cam 235/244 111 LSA (So I’ve heard)
Texas Speed LS3 N/A Cam Stage 3 231/246 111 LSA
Brian Tooley Stage 4 LS3 Cam 233/250 113+5 LSA
Tick Performance Stage 3 Polluter Cam 233/248 113+5 LSA
Any information/advice provided will be much much appreciated. Thank you in advance! Hopefully this can be a good thread for others in the same shoes as I.
Texas Speed does custom grinds and with their lobes its a 230/234 .615 .600 114+2/
I am in the same boat as you and will be going with Spin's cam along with porting the heads for 800 thru TSP.
The thing to remember is that a little bit smaller cam will get you to very close to the same place as a much larger and aggressive cam. But unlike an aggressive cam, it will have much better street manners.
The Cam Motion Titan III 227*/237* 113*+3.5*
or the Titan King 232*/244* 112.5* +3* would be my suggestion.
The huge exhaust spits of +14-18*+ seem to be an older tech for N/A LS3 applications
especially with a good exhaust system. Either of those cams will perform exceptionall
and drive well at part throttle & cruise by reducing overlap from needless exhaust duration.
Either one of those cams combined with a MamoMotorsports (MMS) LS3 Heads & Ported
FAST Intake Could make 530 RWHP+ for the Titan III
550+RWHP with the King, 570 maybe with the Mid-Length Runners in the FAST....
if you are willing to Spin 7200+
Just my .02
Good Luck
When I chose my cam specs, I was in pretty familiar territory. I've had two other cams (226/234 114+2 and 224/234 116+2) with similar duration and lift on unmolested LS3's.
I think the PTV issues Spin was referring to happened when milling LS3 heads enough to be used on an LS2 without losing compression ratio. LS3 heads have 68-70 cc combustion chambers whereas LS2 heads have about 64 cc chambers. It takes quite a bit of milling to get LS3 heads down to 64 cc or less. Quite a bit more than what I did.
Another cam often recommended for street friendly LS3s is a 226/234 .633"/.633" 114LSA +4. This cam I hear is often recommended by a well know tuner on corvetteforum and LS1Tech. PM me for details.
The Titan 2 cam goes in tomorrow and in 3 or 4 weeks it'll get a dyno tune.
Dave
Dave
FYI, cam motion has an exception/outstanding cam guru that helps with cam selection. I'm pretty sure his name is Bobby. He is super knowledgeable, very friendly, and didn't mind answering my dumb questions. Strongly suggests calling him.
If you're open to another cam idea, for an LS3, I might suggest the SpinMonster cam. Spin is back, or was, active in the forum. Lots of examples of his cam and LS3s making great power. Driveability would not be as good as the more milt Titan2.
Both cams will react much better if more compression, especially the SpinMonster cam.
If I had an LS3 and was willing for a somewhat less friendly driver, I would go Spin's cam.
@SpinMonster want to chim in on my thoughts.
To me, a cam that size isn't worth the time and money it takes to do a cam swap. Not a fan of big cams by any stretch, but am a fan of getting my money's worth when spending money on power upgrades. Money spent on a tiny cam like that would be better spent on hookers and blow.
Disclaimer...never spent money and hookers and blow.
There are several cams mentioned in this thread that would be a nice upgrade over the Titan 2. My cam and the T2 have the same amount of overlap. Manners will be the same. I'd bet mine would equal it down low and kill it for total power. I'm guessing you're considering a cam swap to make more power and enjoy your Vette more.
Lots of ways to make power and still have decent manners. If you employ a cam with limited potential, you're limiting yourself before you ever turn a wrench. I'm no fan of the bigger cams that induce buck, surge, and shake either.
Spin's cam would be at the top limit of what I'd consider for a well behaved street cam in an LS3. I wouldn't consider it in an LS2. It has 4 degrees of overlap which some are OK with. There's a huge number of alternatives at similar amounts overlap available if you're willing to go custom. Not much if you're looking for a shelf cam with just slightly less than that.
