05 6 speed ls2 doesn’t turn over
Old Mar 1, 2020 | 04:59 PM
Lisandro Diaz's Avatar
Lisandro Diaz
2nd Gear
Default 05 6 speed ls2 doesn’t turn over
Hope i could use some assistance with this. My car has been giving me this issue for some time now. I swapped out the starter with a brand new one, installed the column lock bypass, new battery, and new battery connectors. At one point i got it to run just enough to get it back home but the gauge cluster was having misreadings and i kept receiving “check coolant level” and “change oil soon” but all thats okay as well. I Tried plugging in the diagnostics scanner but almost fried the scanner itself. I don’t know what else to do and i really just rather fix it myself than to take it to a mechanic. Anything helps, thanks.
Old Mar 1, 2020 | 05:17 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
First WELCOME to the Forum !!...now what do you mean by “almost fried the scanner” ???...I’ve never heard of that !!...what exactly are you seeing on the scan tool ???
Old Mar 2, 2020 | 01:12 PM
Lisandro Diaz
2nd Gear
I plugged the scanner in and it began to flicker and even the car started to flicker and dim out a little if that helps! Thank you for the welcoming!
Old Mar 2, 2020 | 03:59 PM
Dutch08's Avatar
Dutch08
Originally Posted by Lisandro Diaz
..... i really just rather fix it myself than to take it to a mechanic. Anything helps, thanks.
Step one, check the battery terminals (tightness and connection ) , battery voltage .... what errors on the scan tool.
Old Mar 2, 2020 | 04:03 PM
sstonebreaker's Avatar
sstonebreaker
Try wiggling the wire bundle running from the driver's door to the car. I had that issue in an 04 C5. Also check all the ground straps - these cars are notorious for having corroded grounds.
To 05 6 speed ls2 doesn’t turn over
