Dewitts radiator help
Old Mar 6, 2020 | 02:42 AM
James Heracious's Avatar
James Heracious
Default Dewitts radiator help
Does anyone know the fluid capacity of each of the plate oil coolers inside the Dewitts radiator? Both ATF and engine oil coolers. Thanks. Contacted Dewitts and no answer.
Old Mar 6, 2020 | 07:02 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
I never measured it but it is very small. Maybe ounces? Just fill it up and check levels
Old Mar 7, 2020 | 07:11 PM
aahrested's Avatar
aahrested
Just curious, how your install went. I just installed a Dewitts radiator/fan but I'm stuck because no matter how hard I try, I can not push either of the 2 hoses on. The Dewitts is too large a diameter.
Old Mar 7, 2020 | 09:26 PM
jonjoy's Avatar
jonjoy
did you screw the fittings that come with the rad. in>
Old Mar 7, 2020 | 10:32 PM
James Heracious
Mine was a straight forward install. You have to use the Dewitts fittings for the trans cooler. Leave the spring clip in the fitting then press in the transmission lines. It will snap in place.
Old Mar 8, 2020 | 11:13 AM
lsponcho's Avatar
lsponcho
My trans took about 1/4 qt to top off after install. No kidding, direct fit for me. Awesome fit and finish!
Old Mar 8, 2020 | 05:32 PM
Nutzz's Avatar
Nutzz
Super satisfied with my Dewitt's purchase. One year since trouble free install.
To Dewitts radiator help
