Flex Fuel Conversion Question - 05 LS2
Old Mar 8, 2020 | 01:41 PM
csnow's Avatar
csnow
Default Flex Fuel Conversion Question - 05 LS2
I plan to convert my fuel system over to flex fuel during the tear down when I install the Z06 trans/diff and Mantic clutch in my 05. I will be using the A&A fuel system, 80lb injectors, and the DSX flex fuel kit. My question is what to do, if anything, with the stock pump. Is the general conses to just leave it or replace it with a pump that can withstand the corrosive e85? If so, what is the recommended pump that isn't excessively noisy? Since the rear cradle will be out, I figured now is the time but I also don't want the fuel tank headaches if it isn't necessary.
Old Mar 8, 2020 | 10:22 PM
drewz06's Avatar
drewz06
thing knower
swap in a walbro 450, it's direct swap and is compatible with ethanol fuels
