Led lights
Old Mar 10, 2020 | 05:39 PM
nobucks's Avatar
nobucks
Default Led lights
want to install some led strip lights in the 2005 vette in the grill area. want them to come on automatically when you start the car and stay on all the time. Would like to tie into a fuse that goes on at start and turns off when key is off, can't find one ? was going to use the accessory fuse but it is under a small box type cover in the foot well behind a large wire harness, have to pull the harness to open the box ?? any help please
Old Mar 10, 2020 | 11:37 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
. No idea about where to wire but it isn’t a Honda so why ?
Old Mar 11, 2020 | 10:29 AM
nobucks's Avatar
nobucks
isn't a Honda ? not sure what that means ? but all new cars including all Corvettes have LED accent lights, many people are also using LEDs for replacing many smaller bulbs /tail lights /directional etc , why did you bother to even post, obviously don't have a clue
Old Mar 11, 2020 | 11:07 AM
2008 Corvette
OK. How’s this. It is a Corvette, not a Ricer. Your car do what you want but take note of how many of your fellow Corvette owners have lights in the grill. Yes I have all interior LED and exterior LED bulbs that can be changed, except lights in the grill.
Old Mar 11, 2020 | 11:33 AM
nobucks's Avatar
nobucks
they are great driving lights super bright, the factory fog lights automatically go off when head lights are on, wanted something to stay on all the time when driving , all new cars have them , not just ricers , the ones I have are only 1 x 8 inches long in a "L" shape will tuck into the corners of the grill on each side.
Old Mar 11, 2020 | 11:53 AM
2008 Corvette
Default Lights
OK. Try to also consider how bright they are and the possible blinding other drivers approaching you.
Old Mar 11, 2020 | 01:06 PM
nobucks's Avatar
nobucks
i'm 71 yo, been doing car stuff all my life, many car /street rods , Camaros . GTO . etc, fully know what i'm doing , but thanks for your input
Old Mar 11, 2020 | 02:20 PM
2008 Corvette
I am also 71. Ditto to all other comments. Enjoy.
Old Mar 12, 2020 | 10:32 AM
nobucks's Avatar
nobucks
found the fuse to tie into [ HEATED SEAT 10 AMP FUSE ] goes on when you start / off when you shut down,
running wires today
Old Mar 12, 2020 | 11:24 AM
2008 Corvette
Please post a completed picture of the front of your car when done. Thanks
Old Mar 19, 2020 | 03:04 AM
James Heracious's Avatar
James Heracious
A simple fused relay and a 12v switched to the LED lights. I would probably wire in a simple on off switch just in case the police gives you a hard time. Most ADD ON led lights are for off road only s just keep that in mind. You have the right fuse to tap into.
Old Mar 19, 2020 | 10:28 AM
nobucks's Avatar
nobucks
used the heated seat fuse in the foot well fuse box, it is only on when you start the car , got a add-a- circuit adapter from auto parts store, the led's don't draw much power, these are not a off road type lights
To Led lights
