Good morning friends, I am speaking to you from Spain.
I have a newly purchased c6 z06 and with small problems that I would appreciate your opinion. It has 12000m, it is new.
The fuel gauge only marked well from 1/2 to full and I have changed the complete system for a new one in the left tank, now the problem is that with a full tank it marks 1/2 and when the needle drops to 0 the tank is in 1/2, the mechanism may not be adequate?
In the display I have TPMS fault, we have removed the tires and had no sensors, I have bought and fitted them new (4x Schrader tires pressure sensor 3053 rdks TPMS for Cadillac Chevrolet 25758221 433MHZ), but there is no way to code them with the tool, you can that do not correspond to the vehicle?
And finally I get several dtc related to the body control module (b3950-05, b3951-05, b0041 ...) that can happen ???
And do you have a C6 built for the American market or the European market as they used different TPMS frequencies.
FWIW - I believe the original European TPMS sensors were orange in color.
It is from the year 2006, imported from the USA in 2009, it came without tpms with the fault light canceled, but on the way to the house after buying it ... it lit up on the screen, dismounted the tires and had no sensors.
These you bought are 433mhz oranges
