Brake Squeal!
Old Mar 19, 2020 | 12:12 PM
bikejunkie's Avatar
bikejunkie
Default Brake Squeal!
I put New Power Stop Track pads, New SS brake lines, New AC Delco Rotors. I also rebuilt the Stock GM Calipers on my C6 ZO6. Did the recommended brake in 60 mph stop 10x. cool down. 80 mph stop 10x. We put 60 miles on the new pads, and they squeal bad! When I drive thru town at 25 mph they squeal ( when they get warm) I reached out to Power Stop, They want proof of purchase and 3 forms of ID ( sarcasm) before they answer my question. any suggestion?
Old Mar 19, 2020 | 12:15 PM
dr_gallup's Avatar
dr_gallup
Track pads are not optimized for low noise.
Old Mar 19, 2020 | 01:12 PM
Hitman227's Avatar
Hitman227
Yep correct. Track type pads notorious for being noisy on the street.
Old Mar 19, 2020 | 01:18 PM
farmington's Avatar
farmington
Need lots of heat in them.
Old Mar 19, 2020 | 03:29 PM
C6z06man's Avatar
C6z06man
Yep, that’s running race pads on the street. Move to a street pad for low noise.
Old Mar 19, 2020 | 04:31 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Track pads will do this .How many times a year do you track the car? If track pads are not up to temp they will eat your rotor faster.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Mar 19, 2020 | 06:50 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Track pads demand high heat (i.e. continuous hi-speed braking applications) in order to operate properly.....that's why they're called "track pads". In normal street driving, they will be noisy & exhibit LONGER STOPPING DISTANCES than street pads. If you chose not to replace the pads, you could try applying a thin layer of hi-temp grease to the backside of the existing pads....be careful to not get any grease on the face of the pads or on the rotor swept surfaces. Squeal can be caused by rapid vibration of the pad in the caliper & the film of grease serves to dampen those vibrations.
Old Mar 19, 2020 | 07:35 PM
bikejunkie's Avatar
bikejunkie
Thanks guys
Old Mar 19, 2020 | 07:36 PM
bikejunkie's Avatar
bikejunkie
Some body talked me into trying them... My fault
Old Mar 20, 2020 | 11:29 PM
FAUEE's Avatar
FAUEE
The z24 or z26 power stop pads would likely work better for you. But even those street performance pads can be a little noisy when not warmed up. Part of the game with a sports car vs a luxury sedan.
To Brake Squeal!
