I have a 2007 Z51 that I have started auto-crossing and just did a track sprint with in hopes of going for track days when the virus dies down.
I currently have corbotech xp10 pads, redline RL-600 brake fluid, and just a CAI and axle-back exhaust on the car but otherwise stock (performance wise). The only issue I have ran into so far is the oil temp was getting to 255 F at the track sprint because I wasn't always moving so the coolant stayed around 217 while sitting in the pits, preventing the oil from cooling off much. I actually started making "half-speed" runs to get everything to cool off when temps got hot.
What modifications would you guys suggest in order to keep everything cool? I've seen a lot of people do 160 thermostats, but I don't think that would help at a track sprint unless I also get the fans to come on sooner.
255° at the track probably isn't a problem, but if you want to lower oil temperatures you need an external oil cooler. Then your problem becomes getting the oil hot enough when you're not at the track.
I have the same factory water-to-oil cooler you have (2006 Z51 M6). I'm switching to a narrow Grand Sport oil cooler with an aftermarket oil thermostat so the car will warm up.
I realized I probably need a different (since my Z51 has one already) oil cooler. But I definitely don't want any issues driving it around in the cold because I do drive it on roads pretty often, even in the winter. Did a few of companies have oil coolers with a thermostat?
Are there any other modifications needed to keep the rest of the car cool or is the Z51 package pretty much take care of it?
Improved Racing oil cooler block with a thermostat but this will require making AN hoses. Stock GM Z51 will also work. Remember, the coolant warming up will help warm up the oil. When the oil temp exceeds coolant temp, then the coolant will draw heat out of the oil. I have done this setup on literally 100's of C6's, LS2.3.7's. Some bone stock, to track day cars, to full out SCCA legal cars.
A cheaper alternative is a Z06 external oil cooler. It is twice the size of the Z51 external cooler and bolts right in. My experience is it delays high temps at the track but oil still gets hot towards the end of a session. Of course I do live in AZ. I have had no problem getting up to operating temp. It just takes a little longer in 40 to 50 degree weather.
The Z06 oil cooler blocks too much air to the radiator whejn used on a tracked C6.
Dewitts radiator that has the oil cooler in the drivers side end tank. Then add the GM oil lines to connect the end-tank cooler to the ports on the side of the oil filter housing.
The oil will warm up quite fast and be cooled and regulated by the radiator/coolant.
