Having Electrical Issues
Old Mar 30, 2020 | 07:36 PM
sprayed1998's Avatar
sprayed1998
Default Having Electrical Issues
I am wanting to get some opinions on what could be the root cause of the issue I'm having. A few weeks ago I tore apart my engine to replace lifters/heads. Upon putting it back together I started getting a "service charging system" error from time to time. It would only happen when idling and the error seemed to have no ill effects so I just kept on driving. Last week I started having issues with my shifter not wanting to go into gear and not wanting to start. I discovered that if I pressed the brake to the floor hard it would start and release the shifter. I also noticed my brake lights will not illuminate unless I am all the way on the floor with the brakes and the car will not shift into OD (4th) unless I tap the brakes and get back on the gas. So I ended up replacing the brake sensor and that did not fix the issue. I am starting to think the two issues are related. Are there any particular grounds I should check? I have inspected the battery/terminals and do not see anything out of sorts. I have noticed low voltage on startup (8-9 volts) that goes up with a rev and stays in the 13.5-14 range while driving. Even when I get the "service charging system" on the display the voltage is always above 13. Any suggestions would be appreciated.
I forgot to mention that there are times when the brake/sensor seems to work fine and the car will shift into OD, brake lights work, car starts with little pressure on pedal, shifter works fine.
Old Mar 31, 2020 | 11:21 AM
double06's Avatar
double06
First check some of the connections like alternator stud, grounds you might have wiggled/undone or clips that might look on that are not. Check nut on starter and main lug on fuse box. I just changed heads last week and there is a lot of stuff you have going on that could just need a little tightening.
