2012 GS rear end fluid change
I personally use redline D4 atf in the trans and M1LS in the diff
As for fluids when it comes time for the change (read around the 100K range), use the OEM fluid, and not an after market fluid.
The break down on the trans, is that it'ssynco's required the specified fluid for them to last the longest. Use a fluid that has too much slip, and the syncro's will not lock up as intended. Use a fluid that does not have enough slip, and the sycro's end up locking up too fast isntead. Both of these later conditions will cause the syncro's to wear out faster than normal.
On the diff, before you think fluid change, put a torque wrench on each axle nut set to 100lbs, and with just that tire up in the air/trans in gear as you check, axle should not start to slip/turn until you hit the 100lbs. Again, we are using the OE fluid since it has the correct percentage of slip modifiers, and if say you where using a fluid will too much slip, going to cause the diff clutch packs to slip before the 100lbs torque (read a lot of peg leg burn outs). Now at the 100K range of just street driving and the clutch packs are not holding to 100lbs of torque, then it's time to pull the diff apart to replace the worn cluck packs isntead (read do the fluid change when putting the diff back together).
Note, have seen the OEM diff clutch packs burn out in less than 20K with lot of road course work. So again, first check on the diff is the torque wrench to see the torque value of where the clutch packs are allowing release. If below 100lbs, then either wrong fluid being used (not the oem fluid), or clutch packs need to be replaced.
