Input on cam specs for H/C/I LS7?
Old Apr 10, 2020 | 03:13 AM
triblk6spd's Avatar
triblk6spd
Default Input on cam specs for H/C/I LS7?
246/258 @.050, .664”/.632” lift, and 114 LSA
So I'm not an expert on cam specs. I understand what the numbers are but not how they interact with power and/or driveability.
Can yall comment on the cam specs at all? Power...driveability? Idle? Is this aggressive? Streetable?
427 LS7
Bridix BR7 ported
MSD ported
NW 102
2" headers...
Thank you in advance!
Old Apr 10, 2020 | 09:48 AM
JUICED1's Avatar
0JUICED1
Former Vendor
That's pretty similar to the BTR stage 3 cam specs. It's a pretty aggressive cam with a bit less overlap then the BTR. It'll pull hard and sound like a beast. With the 2" headers, ported heads and manifold it should put you in the upper 500s at the wheels. Drivability is subjective and a lot of that is in the tune. It might have some light surging at low speeds but it should drive fine. On a side note, LS7 with a big cam......awesome stuff.
Old Apr 10, 2020 | 03:32 PM
Navy Blue 210's Avatar
Navy Blue 210
Aggressive... Yes LOL
Streetable...... Depends on Tune, Age of driver & Tolerance for compromises.
YMMV
Old Apr 10, 2020 | 07:52 PM
Hitman227's Avatar
Hitman227
Old Apr 10, 2020 | 10:31 PM
triblk6spd's Avatar
triblk6spd
Awwww...thanks guys! That's exactly what I was looking for. Yall are great!
The cam is in the LS7 in may Camaro. Made 590rwhp.
Thanks again!
Old Apr 11, 2020 | 01:24 AM
xBoostx's Avatar
xBoostx
One heck of a combo imo should make around wheel 600 + I have a very similar cam and ported factory heads and it makes just over 600 wheel in a bit different fashion thought my combo is very simple 13 to one compression on E ported factory intake manifold and throttle body Kooks 1 7/8 headers and tho my car is 6L80 and have tall gears 3.42 from factory 2.73 which makes for low dyno numbers sense taller gears reduce resistance which is what the dyno measures.
Old Apr 12, 2020 | 01:34 PM
triblk6spd's Avatar
triblk6spd
Very nice. You are correct. Very similar numbers...you made more power and I made more torque. I'm at 520rwtq. Very nice set up!
To Input on cam specs for H/C/I LS7?
