Base C6 17” Rear Drag Setup
Old Apr 25, 2020 | 03:37 PM
Daniel Jiwani's Avatar
Daniel Jiwani
Cruising
Default Base C6 17” Rear Drag Setup
I have a few questions regarding drag setup. Im thinking about getting forgestar f14 17x10.5 for the rears running a 275/40/17 MT and was wondering could i run a wider tire on those wheels like a 305 and not have any issues with rubbing? Along with that could i also keep the 18x8.5 on the fronts that are on 245s and not have issues?
Old Apr 25, 2020 | 03:52 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
I have Forgestar F14 wheels on my 2011 GS
The rear wheels are 17x11 with a +43mm offset
Rear tires are 305/45 -17 ET Street S/S drag radials
No issues, but my front tires are a taller 285/40 -17
Note: This combo might not fit the base model with it's narrower fenders
In your case, I think you would be better off using the 275/40 -17 MT
Old Apr 25, 2020 | 03:57 PM
Daniel Jiwani
Cruising
yeah i know ill be good on the rears with the 17x10.5 wheels and the 275 tires. Im currently running 305s on my 19” wheel so thats why i was trying to see if i could still pull off 305. Im now more concerned about just being able to run the stock 18x8.5 in the fronts without any issues.
Old Apr 25, 2020 | 04:52 PM
Omega Doom's Avatar
Omega Doom
you can run the 315/35/17 MTs i had this same question the Vette inner fenders has alot more space than you think now are you lowered? if you are its no problem
Old Apr 25, 2020 | 04:54 PM
Daniel Jiwani
Cruising
nah im not lowered im on stock height right now. Thanks for your input!
Old Apr 25, 2020 | 05:06 PM
farmington's Avatar
farmington
A lot of people get 17x9.5 front wheels from a C5 Z06 and run 275-40-17 dragradials on them. I have a set I’m getting mounted.
Old Apr 25, 2020 | 05:07 PM
Omega Doom's Avatar
Omega Doom
yea base/narrow body vettes dont get enough love with the aftermarket lol im going use my 17x9.5 OE C7 Z06 wheels for the drag strip but i have to use a small spacer to clear the Z06 calipers(was on the car when i bought it) i have on my car
Old Apr 28, 2020 | 01:18 AM
HOXXOH's Avatar
HOXXOH
There are 4 OEM wheels in a 17 x 9.5 size ranging in weight from 19 to 22 pounds. Using a 275/40x17 Hoosier will keep your overall weight in the 40 - 43 pound range. That combo will easily handle up to 550 hp. Don't go wider until you're in the 600 hp area.
To Base C6 17” Rear Drag Setup
