74k stock block leak down
totally stock block @ 74k miles.... original heads i'm pretty sure after this test....
cylinder 1 was the worst, but 2 and 7 did the same thing....
edit - i apologize for the shitty video, wasn;t trying to make a documentary
will be pulling the heads tomorrow and tear down the heads to see how bad the valves are....the weird thing is i was making 450/425 to the wheels on the dyno about 50 miles prior to the tear-down..
#7 had leakage out of the exhaust port...
we had two cylinders that were 90/90 perfect, so nearly zero leakdown.... i'm thinking the short block is fine, and the heads are just all fucky...
-drew
