Sticky tire
Old May 4, 2020 | 07:55 AM
Texan79423's Avatar
Texan79423
Default Sticky tire
I want to get sticky summer tire for the street. My current set up is not cutting it. Suggestions appreciated.
Old May 4, 2020 | 09:05 PM
Silver c6 z-51's Avatar
Silver c6 z-51
Mickey Thompson ET Street R
Old May 4, 2020 | 09:11 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Ditto that ...
Of course, if you use them on the street, and don't drive aggressively or do a bunch of burnouts, they still will only last about 2,000 miles
Old May 4, 2020 | 09:19 PM
Silver c6 z-51
I have more miles than that on my set, I don’t do a lot of burnouts but when I do wanna hook up they always seem to take care of me. Of course avoid all rain, lol.
Old May 4, 2020 | 09:23 PM
Turbo6TA's Avatar
Turbo6TA
So, you have more than 2,000 miles on your ET Street R ? (not the ET Street S/S)
Old May 4, 2020 | 09:27 PM
Silver c6 z-51
Yes. Et street R, I have two summers on the tires with roughly 2000 each summer. I run around 20 psi and never had to heat them up much when doing hole shots and spraying with 600 rear wheel horse
Old May 4, 2020 | 09:39 PM
Turbo6TA's Avatar
Turbo6TA
okie dokie ......
I have ET Street S/S ... Would have purchased ET Street R, but everyone I talked to told me they don't last but about 2,000 miles of daily-driver street use.
Thanks for the info
Old May 4, 2020 | 09:42 PM
Turbo6TA's Avatar
Turbo6TA
Jeeeze, I run 27 PSI in my S/S for normal non-race street driving
And 27 PSI won't illuminate the low tire pressure light
Old May 4, 2020 | 10:44 PM
smhigh's Avatar
smhigh
Veteran: Marine Corps
Nitto NT05R Drag Radial
Old May 5, 2020 | 01:48 PM
DSOMC6's Avatar
DSOMC6
Toyo R888R for straight line traction AND cornering.
Old May 5, 2020 | 08:41 PM
farmington's Avatar
farmington
If you aren’t looking for a drag radial but want a summer tire that hooks, I really like my Kumho Ecsta sr91.
Old May 6, 2020 | 05:50 AM
irok's Avatar
irok
Turbo6TA-The M/T R's should last as long as the S/S version as they are the same compound.I get 8,000 miles out of mine.If you drive like an 18 year old you should be able to easily destroy them in under a 1,000 miles
Old May 6, 2020 | 11:41 AM
veneno's Avatar
veneno
whats your current setup
auto or stick? after I did heads/cam, pas3400 I would roast the tires didn't have traction issues when just bolt-ons ( pirelli pzero tires)
replaced the pzero for pirelli trofeo R and hooks good it's r compound street tire and that's 20" rim, lol
Old May 6, 2020 | 09:50 PM
Todds427's Avatar
Todds427
St. Jude Donor '12
I recommend the Perelli P-Zero, great tire, good mileage from them and WAY better than any Michelin.
To Sticky tire
