Please help: ZR1 diff cooler delete what is needed?
going to be putting a ZR1 rear diff and a Z06 TR6060 in my fathers 2005 base vette and need a little help. I believe I need to get (2) -6 ORB to 6an fittings for the trans and a -6 hose with fittings to loop across the inlet/outlet on the trans since we won't be running a cooler. Is that correct? Now how about the ZR1 differential? I assume we pull the heat sink out, remove any lines that comes with the diff, replace the rear cover with a blank version and then I assume I'll need 2 plugs to seal the diff? What size are those plugs? Are they -6 ORB also? Any help is very appreciated.
