Low compression
Old May 8, 2020 | 07:22 PM
00blackc5's Avatar
00blackc5
Default Low compression
Low compression on cyl 3 and 7
45 psi
any thoughts
obly 28,000 miles on it
Old May 8, 2020 | 08:00 PM
Nowanker's Avatar
Nowanker
Pro Mechanic
Thoughts?
"Bad things are happening."
Time for a leakdown test to show where the missing compression is going.
Repairs as indicated....
Old May 9, 2020 | 02:39 PM
Creatre's Avatar
Creatre
Originally Posted by Nowanker
Thoughts?
This.
Old May 10, 2020 | 10:01 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
45 psi
any thoughts
Only bad thoughts. Could be almost anything complicated by two cylinders down.....blown head gasket; stuck valves; broken rockers; etc. Best to find a reputable Vette tech.
Old May 10, 2020 | 11:03 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
In many cases, a head gasket will usually blow in the area between 2 adjoining cylinders. This will decrease the cylinder pressure of both those 2 cylinders.
But in your case, cylinders 3 and 7 are not located next to each other ..... So, it might be something else ? ?
Good luck ...
To Low compression
