I have an 09 LS3 Auto Corvette . I have Texas Speed Long tune Headers And DSX flex fuel kit (E85) And it’s Tuned . It’s also Daily driven. I was looking into making the car around 650-700RWHP . I was interested in the ECS Novi 1500. I was wondering what all I would need for this build, what type of injectors ? Stall converter ? Would i neeed another fuel pump ? Wondering if anyone can put up a full list in what I would need . Also since I have the flex would I be able too run 93 and fill up E85 whenever I’m closer too one ? Or would it be best if I just stick too one like Pump Gas since E85 isn’t all around in my area
Call ECS and ask them your questions. They will tell you everything you need to know.................................... ................................
As far as I am aware there is no available DSP type set up to switch between tunes. You will have to pick your poison. ECS has only done a few thousand set ups like yours, just give them a call. I have the A&A kit which has also been unreal. You can't go wrong either way.
Question is are you looking to hit 650-700 on E85 or 93? If you do it on 93 it takes more boost...if you do it on E85 it takes more fuel system.
Start with a ECS or A&A tuner kit. You're going to want bigger injectors/fuel pump
If you want to make that power on 93 octane I'd say get a cam/torque converter
If you want to make that power on E85 you can get away without the cam and converter
Get a 1000cc injector and get the auxiliary pump upgrade from ECS or A&A
If you are trying to run E85 the same set ups should work. But, if you're looking to get to 650-700 on 93 and want to run E85 on top you'll want a 1300cc injector. On 93 you might get away with a bap but it would be borderline.
I’ve haven’t done anything too the car besides headers . For the A&A kit what all did you have too get or do ? Message me the details ? And about how much are you making too the wheel .
I drove down the coast to A&A and had them install and tune my base C6. The car put out 530 RWHP with a mild tune. The only other engine modification I've done is a Tony Mamo TB.
I added rear wide body fenders and 345 30 19 Nitto NT05R drag radials. I haven't had a chance to take it to Wednesday Night Drags at Sears Point and see how it'll perform. Looking forward
to that when track reopens.
I really enjoy how the car drives and the power is fantastic.
When you install the A&A Kit, what was all needed for it? Are you running headers or any cams or it’s completely stock with a blower ? and what what wide body fenders did you go with any recommendations ? PM me would love too see it
