NPP question
Old May 31, 2020 | 04:33 PM
farmington's Avatar
farmington
Default NPP question
Has anybody just connected their npp mufflers directly to vacuum source without any controller/module?
obviously, at light throttle( high vacuum) valves would stay closed then open at heavy throttle (low vacuum). Almost the same as factory except for the rpm requirement to open.
Old May 31, 2020 | 05:02 PM
CI GS's Avatar
CI GS
I did it for a while after my original NPP controller solenoid **** the bed. It works good too, except that the flaps open earlier than with the factory controller, since the only thing keeping them closed is vacuum, so it functions more based on load/throttle opening rather than being RPM based. Once you crack the throttle open, it’s going to open the valves.
All you have to do is bypass the solenoid behind the right taillights and remove the one-way valve from the NPP vacuum line up front by the firewall on the drivers side.
Old May 31, 2020 | 05:30 PM
farmington's Avatar
farmington
Old May 31, 2020 | 05:39 PM
old motorhead's Avatar
old motorhead
I've been running on straight manifold vacuum for over a year. I like it. I have an NPP in a box for sale if you're interested. I bought it a year ago and never installed it. I like it how it is. The only downside, and it's minor, is that the flaps will open on an uphill grade in 6th gear. That probably has something to do with a bigger than stock cam that I'm running. If it is a bother, just down shift going up the hill. Otherwise, you can accelerate fairly briskly and never have them open. Push a little harder on the right hand pedal and they will open instantly.
Old May 31, 2020 | 08:00 PM
farmington's Avatar
farmington
Exactly what I needed to hear
To NPP question
