Transmission Cooler Lines Disconnect?
Old Jun 14, 2020 | 05:32 PM
crusader9x's Avatar
crusader9x
Default Transmission Cooler Lines Disconnect?
Hey
I have a 2012 Grand Sport that I am trying to remove the transmission cooler lines from. I am trying to disconnect them right at the starter. I already have the smaller of the two lines disconnected but am having trouble disconnecting the bigger one. Is it the same as the smaller one, pull the clip out, then pull the lines apart? Because me and my buddy are lifting our selves off the ground trying to disconnect the bigger line and its not coming apart.
Never mind. Apparently all you have to do is push up on the line coming in from the radiator side while you pull down on the line going out to the transmission side.
