Hello. I have a C6 and a 2007 Suburban and thought I might find the best answer to a question about the Suburban here. It is used off road and doesn't need to pass New York State emissions. I don't have cats but have the rear O2 sensors in stock location. I get codes 420 and 430 and don't want to look at the CEL. I know the computer can be tuned to keep the CEL off but if a dealer worked on it or I ever decided to register it, the emissions readiness test won't show complete, correct? I have tried about six or seven O2 simulator extenders and none of them worked for more than a few weeks. I put my scanner on it and the voltage of the rear sensor is around .8 volts when driving but when I idle, it fluctuates enough to throw the codes. If I get an O2 sensor simulator extender and completely plug the orifice, will that work? All the simulators I have tried have different sized orifices and some even had little cats but none have been completely plugged to keep all exhaust from the O2 sensor. That would keep the voltage steady but not sure if it would be correct value. any ideas would be appreciated. Thanks.
No, you will not pass emissions with codes. Typically Vendors provide/sell simulators, with installation of headers or such, which trick the computer reading correctly. Might try contacting a Vendor here for advice, like Texas Speed and Performance (TSP).
Thanks. I am experimenting with the O2 extenders and found by stuffing them with steel wool, I can control the dampening they provide to the exhaust getting to the rear sensor and it may work. I just wanted to confirm it can't be done thru tuning.
Rear OS sensor are just montoring the cats only. They have nothing to do on how the engine runs, so yes, then can be turned off to they are not reporting errors in the tune.
So in either HP tuner, or EFI live, go into Engine DIAG, and uncheck SES enable boxes and change the last line to no error reported in the list below, then flash the tune back into the ECM with the error reporting changes.
Dano, thanks. I thought they could be disabled so a CEL never illuminated but in states like CA and NY, wouldn't an emissions test show the ECM did not complete the emission test sequence and it would fail if i ever had to have it registered?
I don't believe so - there should/would be no errors reported to the PCM.
Correct, but if NY does a sniffer test on the car, there is no way in hell that your going to get it to pass without cats (at least high flow cats), no matter how lean you run the tune.
You can also fool downstream O2's by installing an O2 spacer. It gets the O2 up out of the exhaust gasses and stops "cat below spec codes". Not needed if you just turn the off in a tune though.
I am using the extenders right now and have experimented with different amounts of steel wool in them to let just the right amount exhaust get to the O2 sensor. It is working so far but think a tune would be better long term solution. I don't have to worry about a sniffer test in my state, just a computer scan for emissions inspection.
I bought HP Tuners and it was very easy to use. I unchecked the codes listed above and also disabled the Catalyst overtemp and Post O2 check. Hopefully that all works and the car will still scan properly. Thanks for everyone's help.
Hello. I am also disabling the rear O2 sensors in my 2013 C6. I unchecked and did no report on the codes listed by Dano but also noticed a few others related to the second O2 sensors. They are P013a thru f and P014a,b. They are all about response time on the rear O2s. I unchecked and did no report on those too. Are those ones that others also disable when not running cats?
Best I remember, there is quite a list of codes that need to be disabled. I suppose you could disable them as they pop up or do a Google search, that is where I found the list.
Thanks for everyone's responses. I had another thought on this. I did disable every DTC code related to the downstream O2 sensors along with catalyst overtemp protection in fuel control and catalyst and post O2 test in engine diagnostics. I have driven it a lot and it runs well with no codes.
Since I still have my downstream O2s installed (just my cats are gutted) could I have just left all the DTCs enabled and driven it to see what codes it threw and then disable just those codes? Would that make a difference in the readiness test when it gets inspected by the state?
For an update on this I did the same modification to my Suburban and it just passed my state's yearly emission inspection so I can confirm you can tune out the rear O2 sensors and pass in states like NY and CA. My Corvette's inspection is due in the fall and I expect it will also pass just like the Suburban
