2005 Wiring Diagrams
Old Jul 21, 2020 | 01:47 AM
TMODcustoms's Avatar
0TMODcustoms
Former Vendor
Default 2005 Wiring Diagrams
Does anyone have a wiring diagram for a 2005, I'm looking for the headlight diagram low beams \ ballast in particular.
thanks
Old Jul 21, 2020 | 10:13 PM
719c6's Avatar
719c6
File Type: pdf
Old Jul 22, 2020 | 01:22 AM
0TMODcustoms
Former Vendor
Thank you! I really appreciate it!
Old May 15, 2021 | 01:23 PM
C-6 Cuda's Avatar
C-6 Cuda
Default Wiring Diagram
i am having difficulty wiring my tach to work. i have an analog tach in my old Cuda.(.2005 Vette eng and trans 4 speed auto). i have installed the resistor to add 12v and still not working. tach is good and has been tested. eng and ECM is a 2005 Vette. Also the VSS wiring diagram i have shows the VSS wire green/white from the ECM is C-1 #28. there is no wire there. Another 2005 diagram shows the C-1 #21 pin green/white. it is there. 2005 is an oddball and things are not consistent or not available at all. i have compared to a 2006. they are very different. any help much appreciated. Larry.
To 2005 Wiring Diagrams
