Support Equipment
ID1300 or ID1700's will cover the vast majority of people/builds. I think ID1300's idle better on gas but I've done it with ID1700's too.
Fore fuel system.
ID1300's MAYBE if you might ever do E85 or turn it up more... ID1000's should be good to 700'ish on E85 IMO. Will also depend on whether you're running meth or not since that will cover some of your fueling needs. On pump they'll obviously be good for closer to 900-100rwhp.
The simple answer is an ECS stage 1 fuel system for that power level. They have a version with a larger pump if you wanted to do E85. It's a simple add on system and they have a nice tank bulkhead. Something like this:
https://eastcoastsupercharging.com/p...o-13-corvette/
Fore makes some really, really nice stuff if you just wanted some fuel pump ****.
https://www.foreinnovations.com/product_p/38-501.htm
Thanks I appreciate it !!! Def will look into it . I’m already on flex as well
