I have a set of NPP Mufflers to install on my Base 2009 with a Cam, LT Headers, High Flow Cats with X-Pipe. I have not received the NPP In A Box that I ordered. If I install the Mufflers now and the NPP in A Box later; will the Muffles be in in Quiet or Loud Mode ?
It will be easier when you have the old mufflers off to drill the small whole in the RR cubby hole and run the vacuum line. Wait and do it all at once.
You can run a vacuum line back there just as the instructions tell you. You just don't have the box. Hooked direct to manifold vacuum, they will be quiet at cruise and loud when you get in to the throttle. My used box that I bought on the forum never worked. I just by passed the box and run it off of straight manifold vacuum. I actually like it that way. You don't have to push a button to get loud. It gets loud instantly when you mat the throttle. Quiet other wise.
You have to run vacuum back there regardless. Just run it through the right rear cubby. You can run it like mine until the box arrives. You just cut the line and install the box in the cubby. Run power to it and you're done.
If you want it in the loud mode just cruising around, then yeah, you need the box. I just don't feel the need to be loud when I'm not wanting to accelerate hard. And I don't have to push a button.
Actually, the hole can be drilled by hand from the inside of the cubby, since the cubby material doesn't even require any more power than your fingers to turn the drill bit. Ask me how I know.
As others have said, it will be in the open (loud) mode but some Z06 and Grand sport owners leave it in that mode all the time. I had added the Z06 exhaust to my car and it added a bass note to it but it wasn't offensively loud to me. I like the sound of electric cars so I prefer quiet. That said, open mode didn't annoy me. I too had the NPP in a box mod.
Thanks for all of your input; I will wait to have the NPP Mufflers and NNP In the Box installed the same time; I ordered one NPP in the Box on 7/22/and another on 7/28 and neither has shipped yet. Not very happy with either of the Forum Vendors that I ordered from.
