crooked steering wheel
I drove the car home from the shop and everything felt normal, tracked straight, the steering wheel was straight. The only thing that was weird was the air pressure in the tires was at 42 pounds (compared to 30).
When I got home, I took the car home washed it, pulled the wheels (to inspect the brakes for an upcoming track day) and aired the tires back to 30# cold.
Today I drove the car to an autocross event, did 10 runs in the session (no spin outs, etc.) and every thing felt fine. As I was leaving I aired the tires back up to 35 (they were at 30 hot) and drove home, when driving home I noticed that the steering wheel is clocked to the right approximately 20 or 30 degrees.
The car seems to track normally and didn't feel weird.
So my question is;
Did the alignment shop not tighten something? How did I do 10 autocross events without noticing it?
Did I break something? If so what could be broken (I can throw the car on a quickjack tomorrow but would need to know what to look for)
Could the air-pressure be off (the DIC showed them all within 1-2 pounds from the lowest to the highest)
I will double check the air pressures tonight after work and make sure they are all set to 30 at rest per the door instructions.
Something changed while you were driving, and I'd be freakin' alarmed.
Something moved, might be anything... loose tie rod end or maybe a camber/caster eccentric. If it moved enough to make the wheel 20-30 degrees off, what's to stop it from moving more, possibly to the point of catastrophic failure (loose bolts falling out...).
I might be brave enough to drive it to the shop, but I'd be concerned the whole time...
Let us know what you find!
Would it make sense to put the car up in the air after work and inspect to make sure nothing is loose? If so, what should I check? If I use a quick jack to raise the car up, can I just tighten check all of the bolts in the suspension and ensure everything is tight?
How can I confirm it will be safe this weekend for the track day?
