Check Engine light
Old Aug 6, 2020 | 11:41 AM
zsking's Avatar
zsking
6th Gear
Default Check Engine light
Hey guys, have a quick question. Had some work done to my 2013 grand sport A6 about a month ago and had a check engine light come on. Initially it went away when I restarted the car, but it came back a few days later after I romped down on it pretty good and now wont go away. It has a cam kit,1 7/8 long tubes with high flow cats, corsa cai and a tune. The code that was read was P0300 "random misfire detected". Any ideas what it could be?
Old Aug 6, 2020 | 11:52 AM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Loose plug wire, maybe?
Old Aug 6, 2020 | 12:00 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Chevrolet P0300 Causes
(* = Most Common)
  • Faulty or worn spark plugs *
  • Faulty spark plug wires or coils *
  • Distributor failure *
  • Faulty fuel injector *
  • Vacuum leak
  • Low fuel pressure
  • Camshaft sensor defective
  • Crankshaft sensor defective
  • Engine timing off
  • Leaking head gasket
  • Low engine compression
  • Poor quality fuel
Old Aug 6, 2020 | 12:12 PM
zsking's Avatar
zsking
6th Gear
Everything seems to be tight. Spark plugs were replaced with Ngk tr55's so I wouldnt think they would have already crapped out.
Old Aug 6, 2020 | 04:01 PM
irok's Avatar
irok
Throw the NGK's in the garbage where they belong.They often cause issue's with our cars
Old Aug 6, 2020 | 05:36 PM
zsking's Avatar
zsking
6th Gear
What brand would you recommend? I heard Bosch was no good.
Old Aug 6, 2020 | 08:06 PM
DSOMC6's Avatar
DSOMC6
Been utilizing NGK plugs and MSD wires for years on a C6 with zero issues.
Old Aug 7, 2020 | 01:15 PM
Dave S's Avatar
Dave S
The Owner's Manual recommends AC Delco which work fine, so why jerk around with some other brand?
Old Aug 10, 2020 | 08:24 AM
SCcues's Avatar
SCcues
Pro<br><img src="/forums/images/ranks/500-1000.gif" border="0">
That narrows it down!!! You’d think the codes might be more specific than that.
To Check Engine light
