Electrical Issues
Old Aug 7, 2020 | 06:05 PM
98c5ls1's Avatar
98c5ls1
Default Electrical Issues
I just recently have got my car back it is a 2006 06 Z06. For some reason my car keeps destroying alternators. I currently have a high performance alternator on there however it does not have a clutch pulley. I installed a new battery when installing the alternator and it drains the battery when I leave the cables connected. I think it is possible I could have a parasitic drain from my cigarette lighter as well because my voltage drops tremendously when I plug in anything to it. What alternator should I be looking to get? How many Amps? Is a clutch pulley recommended? I’m not sure what could be causing these things to happen. Any suggestions on what to do or check? Thanks
Old Aug 7, 2020 | 06:25 PM
double06's Avatar
double06
The problem with these high performance alternators is the pulley is too small and thus at say 7,000 engine rpm it is well over the alternator rpm redline of say 18,000-20,000 rpm. On mine had to increase my pulley size to stay under the 20,000 rpm redline. If you have a stock Z06 size balancer you need a pulley size of like 67 mm to keep under the 20K. I think mine came with like a 58mm pulley.
