C6 6 speed auto - boot lock underneath knob
Old Aug 8, 2020 | 04:28 PM
Andarwa's Avatar
Andarwa
Default C6 6 speed auto - boot lock underneath ****
Ran into a problem which caused me to push the boot lock underneath the shift k-*** down. As I recall it was twisted while pushing down and it popped off the bottom of the k-***. I can't get it all the way back up. The shifter was replaced prior to my purchase, I have the old part, but the original one had a different and much easier locking mechanism, you can't turn it and it pushes up and snaps into place. On the new one there is a guided channel so you can't just push up directly with it aligned. I have to turn it counterclockwise to about a 45 degree angle, it easily slides up, leaving about another 1/8" to go. In that position it can't be turned anymore in either direction, the only direction appears to be a final push up to the base of the k-*** but it won't budge. Sure hoping somebody knows what I am talking about and has the secret recipe to get it back in place.
Old Aug 8, 2020 | 06:56 PM
4SUMERZ's Avatar
4SUMERZ
The attached PDF may help you figure it out,
Good Luck
Old Aug 14, 2020 | 01:11 PM
Orion2011's Avatar
Orion2011
I have the same issue OP. I've tried everything.
Old Sep 9, 2020 | 08:04 PM
Andarwa's Avatar
Andarwa
Thanks 4sumerz for that pdf. It seems the same but I am not getting the same sequence of events when trying to get it back up into place. Tried multiple times. Nonetheless looking at the pictures I see some similar characteristics and will try again.
To C6 6 speed auto - boot lock underneath knob
